919 engine
brookie - 9/9/11 at 10:58 AM
as above need full engine or the bottom end or i may just have the crank rods and pistons just let me now what u got
van cleef - 9/9/11 at 05:51 PM
I have a damaged engine from when the prop worked loose and tore the water pump off.
The block is cracked by the Generator casing but everything else is fine if you wanted to strip it.
It's a bare engine so no carbs,genny,starter motor.
doddy - 9/9/11 at 06:29 PM
i think i have a set of main cases if there any good may have the crank and other bits
jase380 - 9/9/11 at 07:58 PM
This might be worth a punt mate, ebay item no 220846372531. would be a lot easier to drop a new motor in than rebuilding the fooked one.
brookie - 10/9/11 at 12:39 PM
hi jase think i going to look ti see what damsge it done to my yet give me some think to do over the winter lol
i can get a nearly new 1 from andy bates
brookie - 13/9/11 at 05:15 PM
right it now in bits and it looks like i need a crank shells and at least 2 rods so i dont now what to do now any clue what i should do lol
