clocks or digidash options
samjc - 27/9/11 at 05:52 PM
Hi lcb im just starting to put ideas together of what clocks to go for and wunderd if anyones upgraded or has unwanted clocks as im running a pinto 1.6 for now so nothing special but was after the digidash all in one speedos on digitalspeedos.com but not sure. One ideabut seems a.lots of money and work was to ue some rx8 style clocks but havent even started to sus wiring and sesor idsuse id have yet. So any ideas or anyone in the next few months upgrading? ?
russbost - 27/9/11 at 09:19 PM
Remember I can always offer a small discount off the Acewell range of digital dashes - take a look at www.furoreproducts.co.uk
Russ
samjc - 27/9/11 at 10:05 PM
Ah ive.messaged you about the carbon 4" headlamp in carbon on ebay. May need to contact you.on brakelines and the lights in black.
russbost - 28/9/11 at 08:08 AM
No probs, just FYI I will be away on hols from 9th Oct thro' to 30th, so if you're in a hurry for any of it, best get in b4 then!
whitestu - 28/9/11 at 08:25 AM
I got an Acewell from Russ and have been very happy with it. Mine does speed, rpm, water temp, volts, fuel, mileage and trip plus all the indicator, main beam lights etc. Basically everything you need.
Stu
[Edited on 28/9/11 by whitestu]
samjc - 28/9/11 at 09:57 AM
Have to look into the acwells abit need to see one all lit up as i like the style of the digital speedometers on ebay at £250 a friend has one and looks great.
Theirs no rush just yet for clocks but may order the break lines soon their to suit a volvo 740 estate brakes. Only need the fronts but from reading your info on sizing up brake line (very helpful and easly understud) im assuming its the moder style connections. A rough price would be great just 2 half metres in orange or black braided and do you do slighty shorter single ones for connecting to the rear axle as mines tee'd off to copper lines so only one flexi connection to deal with.
david_hornet27 - 28/9/11 at 11:03 AM
I got an Acewell from Russ and cannot fault the product (easy to install and set up) and Russ PM'd me to clarify a few issues I had because I am an idiot when it comes to wiring! Great service and highly reccomended!
coozer - 28/9/11 at 12:28 PM
I have an Acewell and its very good, only trouble I have is over 160mph where it gets a bit blurry... thinking of changing to Koso dials, only really cause I fancy summit different like.... should be easier to see at warp factor 9.
