Evening peeps,
Im after a few YB parts if anyone can help me out. If you have any of the following can you post or U2U me please.
2wd thermostat housing
Water pump pulley
Bottom crankshaft pulley (not the toothed cam belt pulley)
2wd pick up pipe
Rocker cover (Standard i.e. no after market breathers etc)
Distributor
Thanks.
[Edited on 27/10/11 by DixieTheKid]
i presume your a member on passion ford?
that must be one mean car you are building..........
if it needs a rocket cover!!!
if it needs a rocket cover!!!![]()
I got most of my bits from ebay - but it took ages to find ones in good condition at good prices
In the end I gave up tring to find the pickup pipe / oil pump and got new ones from graham goode (~£50 for the pickup pipe I think) - then the next
week ebay was full of 2wd pickup pipes
(they were mostly asking £30+ though)
whats your plan fr the engine ? run it with a turbo and stock ecu, an NA cossie or something really fancy ?
also I take it you've got the cam belt pulleys already (they are different from pinto ones)
if you want cosworth parts, Paul at north yorks rs spares is your man, if he doesn't have it then no one does! i've put his website bellow
for details but my advice would be ring him as being a backwards northerner hasn't quite figured out email etc yet
http://www.cosworthrsspares.co.uk/
quote:<--- yep got these.
Originally posted by mcerd1
I got most of my bits from ebay - but it took ages to find ones in good condition at good prices![]()
In the end I gave up tring to find the pickup pipe / oil pump and got new ones from graham goode (~£50 for the pickup pipe I think) - then the next week ebay was full of 2wd pickup pipes(they were mostly asking £30+ though)
I think I have everything you want on a YB that had one of the bottom end bearings go. The only thing I'm not sure of is the rocker cover. I know
that it has been painted black from the original red but can't remember if anyone has drilled a hole for a breather. Also the distributor cap has
"straight up" connections rather than the ones that come out perpendicular to the unit (if that makes sense).
I'll have a good look on Saturday and let you know for certain. The other good thing is that I'm in Verwood and work in Southampton so
getting the parts to you is easy.
I'll let you ponder over the price - I was planning to strip the engine and put the bits on Ebay.
Alex
^^ what state is the head / cams in ? (assuming DixieTheKid doesn't need them...)
I think the head is OK. From memory the cams were OK (but it's a long time since I looked at them). As I said before, the problem was at the bottom end. If I'm removing the rocker cover, I should get a better idea.
Originally posted by DixieTheKid
Standard 2wd head is going back on which is bare at the moment and needs to be skimmed, all valves, seals, springs and cams etc etc etc will be new. Will probably go for a set of fast road cams. ( not looking forward to the cost of all that lot! ).
Cheers Chris
Originally posted by alexg1965
I think I have everything you want on a YB that had one of the bottom end bearings go. The only thing I'm not sure of is the rocker cover. I know that it has been painted black from the original red but can't remember if anyone has drilled a hole for a breather. Also the distributor cap has "straight up" connections rather than the ones that come out perpendicular to the unit (if that makes sense).
I'll have a good look on Saturday and let you know for certain. The other good thing is that I'm in Verwood and work in Southampton so getting the parts to you is easy.
Alex
Cheers Chris
just my 2 pence worth but leave the cams standard. the standard cams are good for up to 400bhp, a change of inlet cam would give you a little more top end but i've found it to make things rather laggy (BD14) and anyone i've ever known change an exhaust cam unless going for mega power has always ended up going back to the standard cam as they just make the engine aweful in lower revs.
