As title really, I'm after 1m of flexible hose, the stuff like on a Dyson vacuum!! It's to join the carbs to the std airbox.
It needs to be 57mm inner diameter and ideally 71mm ish outer diameter to sit in the air box holes snug.
I've tried eBay etc, but it's difficult to tell if it will do the job and at £30/£40 length expensive for mistakes. I don't mind
paying out a decent price for it if I know it will do the job!
anyone??
Have you tried ap motorstore Mate they are pretty well priced look for the flexible silicon hose
Thanks! There is some on there that might do it, the only problem is I think it will be sloppy at the air box end. Might look into making some 57mm 'standpipes' to bond to the airbox as a solution.
Give them a ring and see if they do induction kit reducers I bought a filter from them and got a load on the box of random sizes but don't know where they are they may sell them separate if you ask
