ive done this job back to front DOH!!!
made my tank straps out of 25mm x1.6mm strips
now i cant find a rubber cover to fit can find rubber suitable for 20mm and even 22mm but not 25mm
i really did want the flat channel with wrap around lips.
anybody know of a supplier.... please
tried the usual suspects cbs and seals+direct
thanks in advance for any help
cheers les g
trim the straps down with a flap wheel on a grinder? its only 3-5mm
will take seconds on 1.6mm steel. and if the lip wraps around, you won't see the edges if they're not completely straight
Use a few layers of heat shrink.
Just split the rubber down the middle and stick it to the strap. If using 20 mm rubber = 5 mm gap underneath
Fred
[Edited on 3/11/11 by Fred W B]
MG T-Type TD & TF (1940s & 50s) used very wide tank straps try this link
Link
[Edited on 3/11/11 by britishtrident]
Cycle inner tube on mine (ones that had a puncture of course, keeping it locost...)..
Dan
I ussed an old cycle inner tube as well, on my home made tank
