Hi Guys
Looking for a length of 5" diameter Mild steel tube 250mm long 3mm thick if possible but happy up to 5mm.
nothing I can find on fleebay is any use.
Are these for the hub carriers? I've just put the enquiry to my steel stockist as I need some but it won't be cheap as it's a non-stock item.
I may have some 5" steam pipe. U2U me on Monday to remind me to look!
Like this.....
j
Nice looking bit of welding Mr Owelly! What are the "half a hole" cut outs on the bearing carrier mounting face for?
I'd like to give you a better reason for those cut-outs but its bacause I used a couple of pipe flanges...
I had a price on this today, 6m length of 5" o/d x 3mm = £113.00 excl VAT
Wouldn't be too bad if enough other people wanted some.
I have 4.5".....
It's steam pipe so the wall thickness is 5mm. Let me know if it's any good to you guys.
