Rubber 'Isolating' Bushes
r1_pete - 24/11/11 at 08:06 PM
Not sure what they are called, which is probably why I can't find any.
The isolating bushes, they are a bit like grommets, which push into a hole in a panel, then bolt into the chassis or whatever, with a crush tube, or shoulder bolt to provide some vibration isolation.
Anyone know the corect name, or even better a supplier.
I'm looking for some to fit a 12mm hole, and take an 8mm shoulder.
Cheers.
Pete
jimmyd - 24/11/11 at 08:32 PM
Rubber nuts? http://www.memfast.co.uk/shop/Vcat1.asp?cat=2250003304
Peteff - 25/11/11 at 09:20 AM
AKA Well nuts used for fairing fixings on bikes.
