Has anyone got any of brackets I could borrow? I've looked round a breakers and none of the engines had them attached.
If not I'll just have to make some up but would rather save myself the time. Do I really need them? Surely chain bolted in will safice?
I use thick rope, or a couple of straps around the engine.
Around the crank and sump?
If the manifolds are off I Just secure a length of chain using a couple of inlet and exhaust studs and some large washers.It is better to support from
the top of the engine as the weight then keeps it steady.
Paul
I have the brackets but Im a bot too far away, unless you want me to post them on Monday?? u2u if needed
Hi andy thanks for the reply, I'm trying a breakers later who reckons he may have a pair, failing that I'll U2u yourself later.
We're they needed in your opinion?
