Right guys and gals, i ve finally cinvinced the mrs that what we need in our new house is a v8 coffee table, ( the mention of it been able to accept
wine bottles in the bores was the deciding factor)
Anyway i had a poke about in the usual spots and they either seem to be at the other end of the country or stupidly expensive for what they are, so
im going to do the work my self get it powder coated and make it look really nice.
So what im after is a v8 block with four pistons and rods condition is not important in fact if it has a crack thats fine as long as its not got any
great chunks missing out of it.
Beer tokens await im prepared to travel within about 50 mile of leeds although the closer the better.
Also if anyone should have a v10 or v12 kicking about i would be very interested.
Thanks in advance rob
Got an RV8 block taking up space, no pistons though.
i can supply a bmw 4.4 v8 with pistons and crank,£40 07957617548
Hi,
You could buy mine!
[img]
engine table
[/img]
Mine has been chemically cleaned with and has no trace of oil left on it, it smells of NOTHING, not even the cleaning agent.
The pistons have been polished and the rods painted in Ford Focus ST metallic black.
You can collect from TF7 postcode or I could courrier it at cost but it may work our expensive.
Glass is 1mx1m if you wanted it or you could just have the rest less the glass an keep your eye out for a suitable sized 99p coffee table on ebay and
pinch the glass from it as it will be safety glass as standard (which is what I did)
£150.00
Col
