As per title, I am after the plug that fits the sensor as shown in the pictures.
Sensor_socket
sensor_socket_B
It is the Ford ECU water sensor plug from a late zetec as I understand it.
beer tokens are available,....
thanks
I used a couple of minature 'spade' type connectors, because I couldn't get a suitable plug.
[Edited on 8/6/12 by r1_pete]
ditto, i was willing so spend the extra ££ on the proper connectors but I couldnt get any.
I will have a look in the mornning as I will be loom building this weekend if the weather is crap.
thanks every one, I had thought of using an injector plug as the inner is similar, but a lot further down a different shape hole,...
appreciate everyones efforts
fingers crossed
If warren doesnt have one I will have a look as I still have one loom left, minus a few plugs.
Also, Warren, if you need any plugs let me know and I will see what I have as still have most of one loom and an injector loom here
Ford doctors the male and female plastic of their plugs to make fitting easier. The 'fins' on the sender only allow the correct loom
connection to fit. If the fins are cut off, not affecting the senders function or locking mechanism then many ford two pin female plugs will fit. Like
so.
[img]
DescriptionPlug
[/img]
Originally posted by Dusty
Ford doctors the male and female plastic of their plugs to make fitting easier. The 'fins' on the sender only allow the correct loom connection to fit. If the fins are cut off, not affecting the senders function or locking mechanism then many ford two pin female plugs will fit. Like so.
[img]
DescriptionPlug [/img]
Ive got one spare of them out of a box full of plugs.
u2 me your address and I will stick it in the post one day in the week.
U2u sent wasa
I still have a zetec injection loom, and with one or two other plugs, but none like the one I need, I am sure that might be of some use to some
one.
thank you all, this is the best forum in the whole web!!
Howard
