Anyone got a spare Drive shaft , Sierra push fit 795mm long
Believe I have one after doing what you have just done on the other side, I will check Dims.
Only problem is that they are heavy and post will cost. You can have it for £10+ post if it is suitable.
Thats great!
Did you have a chance to measure it??
I've not measured it yet but I am certain it will be the type you are after will get chance to go into garage tomorrow am will let you know.
Just give you a visual ,, its the bottom one in the photo i am after
drive shafts
Here it is I believe its same as yours, I measured it at 830mm end to end uncompressed, 28mm diameter.
[img]
[/img]
Thanks for that,
Mine is only 24mm and 795 uncompressed
So not sure its the right one
