Hi there,
Has anyone got the bolts that hold the spray bar on a pinto?
Need all 3 please!
Sounds like your garage is worse than mine Apollo the amount of bits you loose for that engine.
Send me a u2u with your address again and I'll sort it.
Bob
Any short bolts will do
No stress on them, just enough torque to stop them vibrating loose
Cheers Bob you have a u2u,I never had the bolts when I got the head so should be sorted now
