As above wanted .
Complete loom for Striker.
What sort, with/ without ECU, digidash or separate gauges?
I have a previously used loom (believe it is a premier loom but I can check that if you are interested) that has been removed from a xflow powered
Striker with separate gauges.
I am now going ECU plus digidash/ datalogger so am planning to not reuse the old loom but start from scratch
I didn't remove it but it looks like its all in the box including some switches. If you want pictures U2U me your email address and I will take
some over the next few days when I am in the workshop.
PS Just noticed you are in Sussex....I am on the Kent / Sussex border at Hawkhurst if you wanted to come and look at it some time?
[Edited on 22/2/14 by peter030371]
u2u incoming Peter
