Zetec upgrade - Flywheel?
johnemms - 2/4/14 at 01:02 PM
Hi Guys
My 2.0L Zetec Blacktop install is coming along nicely..
Got a brand new Mondeo Mk1 pressure & centre plate with a CTT133 bearing ..
Has anyone got a 1.6 or 1.8 Mondeo Flywheel for sale?
cheers
19sac65 - 2/4/14 at 02:16 PM
Use a late efi cvh one off an xr3I or late 1.4
They have the coil pack on the back of the block - no dizzy
They have the pickup on the back for the crank sensor and the same bolt pattern for the clutch
All you have to do is drill the crank bolt holes from 10-11mm - 2 minutes work
They weigh just over 6kg which is less than some lightweight ones costing £200+
I paid a tenner from mine and it works perfectly and picks up like a bike
Theyre regularly on ebay
Not widely known this,but a great way to get a bit more response
johnemms - 2/4/14 at 03:49 PM
Sorted
Got a 1.8 Flywheel - you can feel the difference from the dumped 2.0L
New centre plate & pressure plate fits perfect..
Another step closer !
