Hi,
I am looking for a 2.0 litre ford pinto rocker cover with the rear oil filler.
regards
Simon
try ebay seen a few on there over last few weeks cheers andy
i have a steel original that i could change to a rear fill for a few beer tokens if you like
Do you need it to be rear fill to fit it under your bonnet? If so, you MAY be able to trim down the filler cap to make it fit, that's what I did
- there are 4 plastic 'lugs' (for want of a better word) just underneath the main top piece. If you trim them off with a stanley knife it
means it will sit about 15-20mm lower, may be enough to squeeze it in...
Pete
Like this...
Or like this (Can THIS image be shown?)
