Well after a mere 200 miles in my newly iva'd and registered roadster my engine decided to let a bucket load of fuel into the sump! Not a happy
bunny! So if anyone has a 2.0 zetec preferably a silvertop then please give me a shout.
Leon
Has it done any obvious damage to the engine? May be a stuck injector or something (depending on fueling) could be easy to cure and need to find reasons anyway then run it and see first could have knackered a bore or bearing but if changing engine what's to loose
I've not yet had the chance to strip the engine down but I've got a significant amount of metal fillings in the oil, so I'm imagining
there's a reasonable amount of damage internally.
Fueling is omex controlled on jenvey throttle bodies.
