Wanted vauxhall manifold to fit a westfield thanks Jonny
[Edited on 26/2/15 by joni]
inlet or outlet?
Sorry should have said exhaust manifold
Bump any one have one
quote:you on wscc? Think there's an SBD one for sale.
Yep I have one for sale, post below:
I have an early SBD exhaust manifold in mild steel for sale - do not confuse with Westfield exhaust manifolds, this has much larger primary and
secondary pipes and was as fitted to a standard XE producing 184 bhp (print out to prove). Link pipe had an exit of 2 3/4 inch. Was originally fitted
to Barry S's car and I have only used to run up my new engine before getting the Simpson system fitted.
There are small small dents to the underside from the chassis rail as shown, could be pulled out if they bothered you but the engine still made that
power as is.
Good for any XE engine running a standard manifold to release a bit more power.
Open to offers.
Barny
