Morning,
Would anyone be able to put a nice bend (90 degrees) into a piece of 19mm mild steel tube please?
I can send dimensions and stuff over if you can u2u please.
Cash waiting!
Cheers.
Yes I can, I have a protools Tube bender with a 0.75" die
This is 0.75" tube
top bone
[Edited on 24/3/15 by liam.mccaffrey]
Originally posted by liam.mccaffrey
Yes I can, I have a protools Tube bender with a 0.75" die![]()
This is 0.75" tube
top bone
No problem, I've got a very nice electronically controlled pipe bender. I'm in Dorset though
Yes its me, 7 years ago when I lived in Oklahoma. I'm about 3.5 stone lighter now
I don't mind paying the postage and for the tube if you have some spare.
The legs each side of the bend need to be about 250mm.
Chris.
What wall thickness are you looking for? Is it to be welded onto something else? or it is cosmetic? So many questions
Marc
I have some 0.75" stuff and probably enough too.
I'll let you know tonight.
wall thickness doesn't really matter as long as it's thick enough to weld. Probably 1.2mm?
Chris
These look ok? It's 19mm seamless pipe with 2mm wall thickness . They will need trimmed back as I've left them slightly longer than 250mm a
side.
Marc
19 mm tubing can be bent by hand without a bender, if wall thickness is above 1.5mm. I bent a few for my locost. I made a wooden jig ( jus a piece of wood with a radiused end 50mm radius). Fixed it to a vise with the tube and bent it over the radius.
