WTD: Zetec Exhaust Manifold
Barkalarr - 10/5/15 at 07:19 AM
Looking for a Zetec Blacktop Exhaust manifold (side exit). Doesn't need a Lamba sensor as running on carbs.
I've got an out of the bonnet Zetec manifold I'm happy to swap
big_wasa - 10/5/15 at 07:36 AM
Just a note but the Tiger one won't fit so your best chance is looking for a Westfield manifold.
Barkalarr - 10/5/15 at 08:04 AM
Just to add, this is for an MK Indy.
austin man - 10/5/15 at 10:04 PM
I used the standard stainless manifold from a later blacktop and had a down pipe made mine exits as one pipe from the side panel. Although you car is on carbs it still may need a cat dependant on the age of the engine if the engine isn't pre april 98 then a cat will be required
