Anyone have a pair of three point inertia seat belts? Don't have to be new just functional and clean.
Preferably with short stems.
Wanting to fit a set into the classic ford Thames van. Currently doesn't have anything.... Kinda scary
Don't you need to get ones for whatever orientation you are using? otherwise the inertia bit doesn't work. There are some aftermarket ones that you can adjust to go whatever way up, probably securon. Or just use simple manual adjust belts, much easier and in keeping.
Hmm, I'd assumed they were all pretty much mounted the same... You are right some Inkeeping ones would be nice. Bit more pricey but would look better
Have set of ex-Westie lap-&-diagonal seat belts, with inertia reels. Could these be of any use to you?
Dick, quite possibly.
Do you have any photos?
[Edited on 17/6/15 by tegwin]
I Have a set of Mustang Rear Seat complete with Anchorage bolts and buckles for the price of postage...
It may be either fast/expensive or Cheap/sloooowww..
They are in great condition...
Let me know if you donīt find anything closer so I remove and check postage...
As they are in the car now, I can take pics of orientation to see wether they would be OK for your install.
No point if you donīt have a suitable mounting point for the reels.
HTH.
AA
Originally posted by tegwin
Dick, quite possibly. Do you have any photos? [Edited on 17/6/15 by tegwin]
