3 hp compressor
Volvorsport - 1/8/15 at 06:14 PM
Looking for a 3hp compressor or advice on upgrading a smaller one . Need to do quite a bit of shot blasting.
big_wasa - 1/8/15 at 06:19 PM
I can tell you a 3 horse is barely enough for blasting.
[Edited on 2/8/15 by big_wasa]
Volvorsport - 1/8/15 at 06:26 PM
Well I'm only on mains so I doubt I could use anything bigger
mark chandler - 1/8/15 at 06:34 PM
You will need a pair of them if you want to sustain more than 20 seconds blasting
Volvorsport - 1/8/15 at 06:37 PM
So tank size and a good cfm rating....
big_wasa - 1/8/15 at 06:38 PM
Most of us are in the same boat.
You want a good size tank, 100 L +
Belt drive.
The best Fad you can get for your money.
My experience, I have a branded belt drive 3hp comp with a 100 L tank and a fad of around 11 cfm. And it runs flat out on a little bench top blast cab, crushed glass as the medium.
It's great for brackets and bits but works the compressor hard.
jossey - 1/8/15 at 06:58 PM
as above you need 2.
I have a sip 3HP AND a 2hp small compressor (clarke £100) and it lasts 30 mins working.
Volvorsport - 1/8/15 at 07:06 PM
So in reality , I need to buy a new 3 hp one to use in parallel ? Not sure I need 30 mins of usage tho.....
gremlin1234 - 1/8/15 at 07:19 PM
I can tell you a 3 horse is barley enough for blasting.
I thought barley was what you fed the horses
ianhurley20 - 2/8/15 at 09:19 AM
Or - you can use electrolysis to remove rust etc
austin man - 2/8/15 at 08:47 PM
what are you blasting ?? an option may be to consider a good Jet wash and do the water ?sand blast
Volvorsport - 2/8/15 at 08:51 PM
Rear axle (live) , subframe , wishbones , quite possibly engine bay and underneath too
austin man - 2/8/15 at 09:24 PM
have a look at the water blasting there is a kit on Ebay that attaches to a jet was needs to be above specific pressure though keep the dust down
