S2000 throttle bodies and ECU. Preferably Emerald or Omex ecu and any throttle bodies. Jenvey omex.. Anyone know of anywhere to get these 2nd hand i imagine they are hard to get
Saw these on eBay they may do the job but I have not used them so others that have will have to vouch for how good/bad they are. But they look good
value and available in different sizes.
4 Cylinder DCOE 50mm Throttle Body Kit inc TPS &' Ram Tubes - Performance &' Race
You will need to get someone like bogg bros od danst to make up a manifold though. And sort out injector ports etc.
Or these look good value as well.
Roller Barrel Throttle Bodies ITB (R500, kit car, DCOE, caterham)
As for ecu there is this
http://www.turbosport.co.uk/showthread.php?t=861008
Or a step up uf you need to go sequential
http://www.turbosport.co.uk/showthread.php?t=861543
[Edited on 20/9/15 by Ugg10]
Thanks for all that info Ugg!
Also came across this ecu, started a thread on it, sone interesting features at a great price. Again no idea how well it works....
http://rrrshop.co.uk/ecumaster-emu-1-p.asp
Oem Ecu and throttle body will work fine if you put the time into sorting the loom
don't no if you will be interested but I have a set of danst engineering gsxr 1000 throttle bodies and manifold to suit zetec and also have dta
e48 ecu for sale to suit with loom if your interested my number if interested 07528606907
thanks luke
Thanks Luke, will ring you tomorrow. If I dont et a chance my numbers 07549982326. Gimme a call whenever if you dont hear from me and we can discuss!
Thanks.
Cal
