108 pcd CXR or similar 13 alloys wanted
se7ensport - 18/12/15 at 06:02 PM
6x13 ET 0-18 and 7x13 with offset around 10-24, happy to buy in pairs.
Alex
jeffw - 18/12/15 at 06:38 PM
I have a set of CXRs 6J x 13 and 7J x 13 with Avon ZZRs on them ....
se7ensport - 18/12/15 at 06:50 PM
Hi Jeff
U2U on way
bigfoot4616 - 23/12/15 at 05:35 PM
not sure if jeff got you sorted but i have a pair of 6x13 CXR's, think they are 108PCD(ford PCD?) and -7 offset
just noticed you don't want lower offset than 0 so probably no good to you anyway.
[Edited on 23/12/15 by bigfoot4616]
se7ensport - 25/12/15 at 05:59 PM
Still looking, need at least 2 pairs, possibly 3.
mark chandler - 25/12/15 at 07:39 PM
I have a set of genuine minilites 6" and 7" available (8 wheels in total) that I have used as staggered pairs on my car, 1 lot with slicks, the other with road legal tyres if you are interested?
I will have to check the offset however.
[Edited on 25/12/15 by mark chandler]
se7ensport - 25/12/15 at 08:48 PM
Do you know the inside diameter as they need to clear wilwoods front and rear which has ruled out my ford 4 spokes (CXRs do work)?
Slicks would also be interesting, ultimately I need three set-ups for my car 1. using list 1a tyres for competitions. 2. something to have fun on track with so 1bs or slicks. 3. set of rims (potentially just for the rear) to run old tyres on for go-motorsport demonstration days (slow speed drifting).
[Edited on 25/12/15 by se7ensport]
mark chandler - 25/12/15 at 10:00 PM
They clear willwoods, I have Sierra discs and calipers on the rear which they also clear albeit with cut down springs.
They could do with a refurb where the laquer has lifted which has never never bothered me, only replacing as I want 8" on the rear.
If you are coming up the M4 soon borrow a set to try, I,m 15 minutes from Newbury.
rears 2 X have slicks and 2 X decent yoko 048's list B, fronts have 2 X slicks and 2 X new 539's list 1a
mark chandler - 26/12/15 at 11:15 AM
Hello Alex
They are not marked with ET so using a tape measure so very rough!
From the back of the face plate to the back of the wheels on both are 4.5", on the 6" wheels back of the face plate to the front is 3.5" and the rears 4.5" (deep dish)
Although this seems wrong, the wheel rim measurement is inside the bead hence the overall width being 7" & 8" respectively.
The slicks are Michelin pilot 20/54/13 rear (fitted) & 16/53/13 (thrown in, not fitted) front, plenty of life in these although a bit old.
Fronts yoko 048's X 2 borderline legal (fitted) 185/60/13 & yoko a539 (fitted) new last year, less than 100 miles
Rear yoko 048 205/60/13 (fitted) lots of life in these.
So you have a set of list 1b ready to go (they are/were my wet set), slicks for sprinting in sports libre/track days (worked well last year) 4th out of 70 cars and 1/2 set for auto solo's, and MOT's combined with the rears.
I would be looking for £550 for the lot.
HTH
Regards Mark
[Edited on 26/12/15 by mark chandler]
se7ensport - 26/12/15 at 01:24 PM
Thanks for all the details and the price seems very fair, unfortunately the rears wont fit. My existing 6inch fronts with ET0 measure 3.5 from the inside face to the front of the rim, but my 6inch rears with ET18 are 2.75, beyond 3.5 and the tyres are past the bodywork.
Still looking folks.
mrnoluck - 9/1/16 at 11:28 PM
I have 2 very light weight Braid Formrace 132 wheels, not sure of the offset or width, can check if you are still looking.
