200mm bench grinder - what spec/make
v8kid - 25/2/16 at 02:20 PM
Hi Chaps,
I need to replace my knackered Chinese bench grinder and at the same time have got a larger lathe that uses 20mm square tooling so it seems sensible to splash out on a better model to grind this tooling.
What spec should I be looking at? I guess no universal motors but what wattage of induction motor is adequate? Although 20mm square HSS will sap some power its only for short periods to allow cooling down. I also have a selection of solid carbide tooling which I have never sharpened before is this harder on the grinder motor?
Another concern is the bearings which foobarred very quickly on the cheapo grinder - are these replaceable on better models and so which ones.
Any recommendations based on experience would be much appreciated.
Cheers!
[Edited on 25-2-16 by v8kid]
trextr7monkey - 25/2/16 at 10:41 PM
Not an expert by any means but buy one with a lamp fitted we have a couple of Clarke things at work and a large wet stone for the chisels but would look at Axminster next time. Green grit wheel for lathe tools
Minicooper - 27/2/16 at 10:03 AM
Stakesys have a promotion on the femi range of bench top grinders, there is a discount code for 10%
GRINDER10
I believe they are pretty good
Adamirish - 27/2/16 at 12:04 PM
I have a record power bench grinder and it's very good. It's probably 7 or 8 years old now and still going strong.
