Before I go out and buy the below items new, has anyone got any of the below which they may have accidentally ordered incorrectly, or never got round
to fitting?
Set of standard Zetec 8mm ARP Con Rod Bolts
Set of ARP Flywheel bolts for 2l Zetec
Gasket for Raceline sump (believe this is the standard silver top gasket)
I have a set of ARP flywheel bolts....
I've got the rod bolts.
Shooter
Shooter
FYI, the Sump gasket is the std Silvertop zetec one
