Hi All,
Needing upper and lower ball joints which suit a MX5 hub and Westfield wishbones - in Northern Ireland this weekend (20th August)!!
Does anyone have any??
The upper balljoint used on the Mazda based Westfield's is the outer tie rod from the 7-series E32 1986-1994 BMW (and many other models also)
Firstline part number FTR4161
The lower ball joint is from the donor MX5
[Edited on 19/8/16 by Smokey mow]
