rover sd1 radiator and rover v8 waterpump
alfas - 6/9/16 at 09:10 PM
i´m searching a radiator in useable condition for a v8 rover sd1 automatic, also a waterpump for a 1979 rover sd1 v8, 3.5l, if possible with viscous coupling for fan
swanny - 7/9/16 at 07:28 AM
i had my Sd1 Rad made at grantham radiators. wasnt very expensive at all and i got the comfort of a brand new one.
(im paranoid about cooling)
alfas - 7/9/16 at 09:05 AM
i´m after a 2nd hand one as new ones burst my budget, i guess
important : i need it for an automatic with integrated cooler for the gearbox oil.
by the way: how much did you pay?
swanny - 7/9/16 at 09:27 AM
from memory about £120 quid
coozer - 7/9/16 at 09:33 AM
I'm using one from a taxi.. Has the built in tranny cooler.
LONDON TAXI TXII TX2 2.4 TDi DIESEL RADIATOR *NEW*
Jamesc - 7/9/16 at 09:52 AM
I bought a collection of RV8 parts some time ago for not much money. It's from an early CKD I think. I'm almost positive there is a good condition pump in there, but I'll have to check. Can you find a picture of what it looks like?
alfas - 7/9/16 at 11:18 AM
water pump is this type:
alfas - 7/9/16 at 11:19 AM
120pound? that was cheap...but i guess it wasnt for an automatic?
anyway...the radiator will be for a SD1, as its an unmolested car i want to keep it original, so an alternative radiator isnt what i search.
Chris_Xtreme - 7/9/16 at 05:56 PM
is this waterpump of any use?
[Edited on 7/9/16 by Chris_Xtreme]
alfas - 7/9/16 at 08:20 PM
of any use? what does that mean? i´m searching exactly this type of pump!!!
Chris_Xtreme - 7/9/16 at 08:50 PM
do you need the pully below the pump too?
where are you in the country? I am in New Malden SW London
I don't need the whole engine anymore, it as far as I was told when I bought it years a go is a 3.9, from a auto rangerover. doesn't look that nice in the rocker covers. I bought it for a couple hundered quid to use as a sizing exercise, ended up buying a car with a v8 already in as it was too much monocoque changing to squeeze one in. (no inlet stuff, already passed that on)
I haven't looked into how much any of this stuff is worth, so you could get me on a not fussed day, so make me an offer
alfas - 7/9/16 at 09:36 PM
hi, the umpo needs to have exact the same long shaft with a thread on the end as in my picture.
your pictures only show the inside of the pump.
Chris_Xtreme - 7/9/16 at 10:11 PM
i'll see if I can take the pully off tomorrow so you can see what hides within, but I guess it doesn't match then as the thread on the outside of the pulley where I figured the fan might go (it had a rubber cap on it for in the range rover) it pretty wide.
Chris_Xtreme - 7/9/16 at 10:15 PM
ROVER SD1 3.5 V8 WATER PUMP
Chris_Xtreme - 7/9/16 at 10:16 PM
also my one doesn't have the pipe coming off the side of big pipe. if you know what I mean!
alfas - 8/9/16 at 06:46 AM
yep...the ebay pump is the same model.....but the seller states "no overseas" bidders...so i´m out.
by the way: range rover or 3.9l pumps arent the same!!! they fit, but they have a different shaft-end where the fan sits, so not useable in a SD1
[Edited on 8/9/16 by alfas]
Chris_Xtreme - 8/9/16 at 06:52 AM
Thanks for the education I have never got my head round the different fronts to the engines.
Try messaging the seller, you never know.
Good luck with your hunt.
alfas - 8/9/16 at 07:34 AM
more "education"
http://www.gomog.com/allmorgan/pumps.htm
http://www.v8wizard.com/Water_Pump_Identification.php
https://books.google.de/books?id=gmSavy1RPxEC&pg=PA60&lpg=PA60&dq=rover+v8+waterpump&source=bl&ots=nh6v4revuZ&sig=reW2iWbgMB_X OBmXonpBehx5dNQ&hl=de&sa=X&ved=0ahUKEwjDxquWoP_OAhVLGhQKHRd_AFUQ6AEIZDAM#v=onepage&q=rover%20v8%20waterpump&f=false
3 types in p5, p6 and sd1 (in terms of pulley and fan)
15 different types in range rover and discovery (mainly in terms of pulley and fan)
and so on....
http://www.rimmerbros.co.uk/Item--i-GRID800036
the basic layout is roughly always the same....which makes it easy when searching such a pump for a rover v8 in a kitcar, as here you dont have to take care about viscous fan etc.
but when it comes to such a pump in a production-car...things become more complex.
Chris_Xtreme - 8/9/16 at 11:55 AM
well mine is definitely wrong for what you are after
thanks for the reading, the kit car I bought with a v8 already in it has the water pump area blacked off and a electric water pump instead, due to space restrictions, so I never got round to learning about the different options.
cheers
Chris
Chris_Xtreme - 8/9/16 at 11:57 AM
billingham is miles and miles away from me(the ebay item). else I'd offer to try and get it for you and post it on, can I guess you are in Germany?
alfas - 8/9/16 at 02:41 PM
yep...exactly.....but i guess the ebay-seller is shiiping it within UK?
Chris_Xtreme - 8/9/16 at 02:44 PM
As far as I read, collection only.
alfas - 8/9/16 at 09:07 PM
yeah, you are right...very strange that such a small item is for collection only...hardly any chance to sell it nowadays
