Im after a set of coilvers suitable for an IndyBlade.
Or just a pair would do for the time being, as its only the rears leaking.
thanks
Not being au fait with indyblades what length dampers do you need, I've got 2 pairs of gaz under the work bench not doing anything.
Shooter
Thanks, i will try and get dimensions tommoro.
Its a 2004 Indy with IRS - if that anyone else reading this can assist with dimensions..?
I only mention the fact i was a BEC, due to the reduce weight.
If the shocks are no good for banana, I'm after a set for a locost
[Edited on 14/9/16 by andygfc]
Thanks!
How do the gaz measure up shooter?
Hi. Ill U2U re Gaz dampers.
Cheers Matt
Sorry guys,
1 pair are 11" and one pair are 15"
Shooter
Thanks anyway -
Anybody else?
Bump
