Shock absorber brackets, but not Rogue Engineering.
They do not respond!!
How many brackets are you wanting I'm having a batch of Roadster brackets cut this week.
Just a car set, (8) but I think 32mm and 1/2in hole
Roadster damper brackets are 34mm id with 12.1mm holes although you could drill them out £2.50 each plus postage.
[Edited on 2/10/16 by Talon Motorsport]
Just a positive observation - 12.1mm is perfect for reaming out to 1/2". You'd then have just the right hole. Reamers are cheap - just be sure to buy cutting oil as well.
Thanks Talon 32mm would be the size I need.
Thanks Furyrebuild, I have reamers, quite alot actually, and cutting oil
Colin
