As above.
Or any other suggestion to get my CBR929 digi clocks working..
thanks
I had a yellow box but it only just had enough adjustment to get mine legal and the steps as are limited. A SpeedoHealer is a better choice and what I switched to. Easy to set up, bigger (infinite) range of adjustment and small steps so easy to get accurate.
Do you have to get a SpeedoHealer for specific bike makes? Or is is just the cable thats different?
I've seen one for a Yamaha second hand, but i need it for a Blade.
Just the cable that is different?
thanks
thanks
I think the difference between the different units is just the plug+play cable/plug. The one I got (eBay) didn't have a plug and I just spliced into the loom. Think I found the wiring diagram on their site.
