Testing the water
Anyone got some Striker pinto engines mounts gathering dust .
Please pm me
Are they the same as crossflow ones? Escort xf ones work on a pinto in an escort, but i'm not sure with a striker if the same applies.
I have sylva crossflow ones knocking about somewhere, if they're of any use make me an offer.
I take it you've got the later chassis with rubber bobbin mounts bolted flat to the chassis?
If you have the early chassis with welded in cradles for original escort mounts, it should be ok with a pinto on xf mounts, iirc the pinto is slightly
wider so different rubber bobbins may be needed to locate correctly.
Dave
Hi Dave
Would be for the later chassis without the cradles
I replaced a xflow engine in my locost with a pinto using the same mounts, no problem. I had bought the aluminium sierra mounts and bobbins but didn't need them.
Pinto in a Stryker......... Sacrilege
Go on, Strykers aren't that bad.
Originally posted by benchmark51
Go on, Strykers aren't that bad.![]()
I've got some from a CVH, dunno if these are any good?
