Hi I'm trying to find a T connector for my pipe from the radiator bottom to the water pump. The small connection to take a pipe up to the bottom of my expansion tank .The two large ends of the T need to be 38mm od and 32mm od and the smaller end needs to be about 15mm od- need to double check this but I think it's right .I'm not sure if this joint is available from anywhere or not ?I've looked in the usual places without any luck .maybe somebody has one at home they don't need or maybe somebody knows where I can buy one from. Cheers .
car builder solutions do a stepped tee thats close to your dimensions
quote:That's one of the few places I've not looked .just been on there and they've got all the connectors I 'll need . I'm very pleased now ! Thanks for the help .
Dont know anywhere that does stepped sizes on a t-piece like that. Maybe try these guys or have a look if you can do it with a t-piece and a reducer
pipe?
Viper
Speak to these guys they may able to help
http://www.autosiliconehoses.com/
Bryn @ Allyfab used to make custom aluminium T's. Not sure if he's still going; if not, it shouldn't be too hard to find someone to tig together what you need.....
Cheers everybody ! I 'll have to check these places out and find the best place to get sorted !
did you get one? found one in the garage at the weekend, but its 38mm from memory on bot ends and 15mm in the middle. yours for the postage
Thanks for all the help .I managed to get some flexible hose that reduced from 38mm to 32mm and I've ordered a T from viper that's exactly the right size .I'm just going to get a short piece of 32mm straight hose to come off the bottom off the radiator then it's job done .So yes pretty much sorted thanks .
