As above wanted .
Any out there??
Bttt
Bit of scrap Ali, jigsaw and a hole saw are all you need.
Sump off, lay on Ali scribe around the Edge, drill the bolt holes and cut out with jigsaw.
Hole saw, Google a few images then start making holes. one for the return, 1 for the pickup and a couple under the crank. Job done, 1/2 hour and very
locost
