As the heading I'm looking for the above for the obvious reasons, I would prefer running Windows 7 , as it's going down the workshop
external condition not important.
Shooter
Not sure if it would suit your needs, but you are aware that you can get a USB-to-serial-port adapter(cable), right? That's what I had to do in
order for my laptop to com' with both my Race-Technology Dash2 and my Omex 710. Just an option to consider.
Good luck.
Steve, in the NLs (who will be taking the MNR to the tuner later today - woohoo!)
Originally posted by ElmrPhD
Not sure if it would suit your needs, but you are aware that you can get a USB-to-serial-port adapter(cable), right? That's what I had to do in order for my laptop to com' with both my Race-Technology Dash2 and my Omex 710. Just an option to consider.
Good luck.
You can also get Bluetooth serial adapters.... avoids having to run wires and balance laptop in difficult places...
USB>Serial adaptors work well but there are two (at least) different chip sets. IIRC the Emerald K3 ecu was only compatible with one of them so may be worth checking to see if the kit you are connecting to has a preference.
The USB-serial adapters with FTDI chips usually work well for connecting to ECUs etc.
I have a few USB to serial cables all work fine all cost a few quid off eBay
Yup got a connector but I need a laptop down the workshop so I might as well get one with a serial port.
Shooter
I have a Dell one here with a new battery in it, decent spec...
What sort of money are you looking For?
Shooter
