I have a part that needs machining on a lathe.
Needs screw threads at either end and a taper in the middle. Overall dimensions are 95mm long, 14 / 15mm diameter.
I have a step file and engineering drawing, I'm just double checking the dimensions. Required tolerance will need to be something like 0.05 / 0.1
mm.
I need 1 piece made out of pretty much any old material as a prototype. The finished parts (2 off) will be high tensile stainless.
Anyone fancy doing it?
TIA
