Hi Guys,
Just wondered if anyone has an intake manifold lying around suitable for a 2.0 blacktop zetec.
i intend to use it with the standard injectors and throttle body.
Thanks,
I think I have a plastic 1.8 one, which I believe is the same as the 2.0. I have a 2.0 one as well but the numpties delivering my engine managed to
break it.
Would need to have a rummage in the garage to confirm though.
Sorry, didn't write this very well, i'm after something that looks a bit like this:
[Edited on 20/11/17 by pekwah1]
Sorry - I see what you are after now.
Stu
GBS sell similar but pricey https://s18.postimg.org/b8gdksmex/plenum.jpg
[Edited on 20/11/17 by chris]
Hi Andy,
Here is one that i have ordered from the Scottish kit car centre? Worth a look and they supply the standard ecu with pre wired loom aswell, all plug
and play.
http://www.kitcarparts-scotland.co.uk/ford-2-0-zetec-maxi-torque-inlet-manifold/
Mike
U2u sent. Regards Jim.
Hi, I have an unused GBS zetec inlet and throttle body £150 plus post
Good information but only needed if you have a Fury
thanks all, i now have a manifold sourced!
