Hi all as title does anyone have some uprights lurking in the garage. or even better does anyone have a spec sheet with all of the dimensions on .
thanks for looking
You don't say which kind of upright you're after, but if it's Sierra front uprights, here is the Ford blueprint
https://drive.google.com/file/d/1bo6uMrAhXP09qzBmxsk_kmhovkFp-
dl6/view?usp=sharing
Hope that will help
Ooops! Sorry! I feel stupid with this post. I didn't get "Viva" referred to the model of the car, like in "Vauxhall
Viva".
This car is called "Opel Corsa" in my country. So am I half excused?
[Edited on 3/2/19 by voucht]
Haven’t seen or heard of a Viva in years , didn’t the Chevette use the same upright?
Viva and chevette are different PCD on the hub, although the uprights look similar. Viva uprights were popular in Autograss circles
Also look for Opel Manta and first Vauxhall ( RWD ) Cavalier. I think they all shared the same basic GM Europe front suspension. As a design it is a good call, more compact and lighter than Cortina. Probably like the proverbial hens teeth now though. Good luck!
Most chevette and Manta have bigger tapers for Balljoints than viva iirc and are 4 x 100mm odd whereas viva is slightly bigger imperial measurement,
think maybe same as Mini?? 101.6mm.
TJ Motorsport do alloy hubs for chevette and Manta, weight saving and choices of 4x100, 4x108 Ford and Ford gp4 fittings
DopDog, I have Manta/Chevette uprights on my Cyclone. I could try and take some basic measurements in situ if it helps. What is most important to you?
You may find one of the Autograss manufacturers make Viva spec fabricated uprights, be right money too.
https://www.shop.drdracingproducts.com/product.sc?productId=166&categoryId=4
http://berrisford.co.uk/index.php/parts-components/steering/front-upright-rh-off-side.html
http://berrisford.co.uk/index.php/parts-components/steering/front-upright-right-hand-with-caliper-mounts.html
thats great thank you
Have a look at classic car scrapyard finds on Facebook
Hi, in case you are interested, I have a pair of viva hubs off my Striker
And also a set of Rostyle type steel wheels and tyres, PCD for Viva (4"?) front and Ford (108mm) rear, it took me some time to realise that they
weren't the same front and back!
Let me know if your interested or would like further info - sorry no uprights though
[Edited on 8/2/19 by Toys2]
