I currently have a fixed column in my GBS, turns out while the set up works well for me, my wife would like the column further back. Thinking a adjustable column would be best, anyone got one?
Adjustable seat would be easier!
Originally posted by CosKev3
Adjustable seat would be easier!![]()
Taller wife?
Already taller than me, only just got this one as well! Issue is if she has the seat far enough back for her legs it's a bit of a stretch for the wheel. I find it ok for me, but thinking an adjustable column would be much cheaper than a new wife.
Might help if we knew what column you have at present? If an adjustable column is not available how about a quick release steering wheel with different dishes for each of you?
It's a Ford based GBS, so Sierra but mine is a fixed column, believe there is an adjustable version available.
Could be wrong but I thought the adjustable type just allows the steering wheel to be raised or lowered not extend?
Sorry to correct, but the Sierra column does extend/retract as well as up/down.
There you go. Ford at it's best. Mine does.......
I have an 'adjustable' Sierra type column in the garage (and a couple of fixed ones too). The adjustable one I have does allow for fore/aft
movement BUT it does not telescope, rather the whole column simply moves in relation to the mounting bracket.
If this is normal for the Sierra 'adjustable' columns there's still a problem to be solved - assuming the rest of your steering linkage
is solid tubing and joints...
That sounds correct. The canter triangular part that gets joined at the universal joint will slide in and out when installed /anchored. There is a nylon sleeve fixed to the triangular section to assist in the sliding. Suffers a bit from stickshon if it has not been moved for a while.
^^ I was kind of thinking - would an adjustable pedal box be a cheaper / easier way to do it ?
otherwise maybe looking for more modern columns or possibly just the mk3 Granada / Scorpio one - its very similar in design to the sierra, but
with different switchgear and more adjustment
the mounting point is a little different though, but nothing too difficult if you've got a welder
some pics of one out of the car here:
https://www.ebay.co.uk/itm/FORD-GRANADA-SCORPIO-STEERING-COLUMN-COMPLETE-KIT-CAR-/361955241380
go to 5:10 to see it working:
[Edited on 6/6/2019 by mcerd1]
Just to aid the discussion and what an adjustable column looks like - IN/OUT and UP/DOWN. Here are some pics.
There are more in my photo archive.
column1
Column_2
The second picture actually has a blanking plate in so that the UP/DOWN function was inhibited for the IVA. This is due to the fact
that when in the lowest position, there is a chance that the ignition lock would jam against the lower cross rail in the event
of an accident and prevent it collapsing.
To fit in the Fury, the mechanism has been reversed otherwise the locking lever hits the cross member and protrudes into the knee space.
The lever also gets chopped as it is too long and hits the bulkhead.
Have fun.
