Hi,
A friend of mine is restoring an old Massey Ferguson 148 (I think) and needs some little rubber grommets/standoffs which go behind the radiator grill
to stop it rattling. They are designed to push into about a 6mm hole and have a conical shape about 12mm in base diameter. See photo below.
Rubber standoff
Does anyone know what these are called and where I might source them? I tried Woolies Trim but no joy.
Thanks,
Craig.
Try searching for isolation washers or spacers
Panel buffers or bump stops.
They use something similar on the toolbox of my Vespa.
https://www.ebay.co.uk/itm/Vespa-Side-Panel-Door-Rubber-Buffer-12mm-Sets-of-5-VESPA-V50-PV-ET3-PX-ECs/283275143992?_trkparms=aid%3D111001%26algo%3DREC
.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D9dfdf4991952480d98b17a31c703c59c%26pid%3D100675%26rk%3D1%26rkt%3D15%26sd%3D283275143992%26itm%3D2832751
43992%26pmt%3D1%26noa%3D1%26pg%3D2481888&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3A06d1c2b7-c9be-11e9-8903-74dbd1801c67%7Cparentrq%3Ad
964d86216c0a9e42e41eeb1ffe25048%7Ciid%3A1
https://www.ebay.co.uk/itm/323806604138
Thanks guys, I knew I could rely on the LB forum!!
Special mention for ReMan - I was too busy trying to figure out what the generic name for this item might be that I never thought to look for it
directly!
I have passed on the details to my mate and I’m sure he’ll want me to pass on his thanks too.
No problem, I was curious!
I know they not exact same profile as the rotten ones but perhaps they were previously replaced.
Perhaps check the parts book
Craig
Your pal might want to check out: https://www.anglo-agriparts.com/tractor-parts-massey-ferguson-148 as well as Hamilton Brothers in Lanark or
Tarbolton: https://www.hamiltonrossgroup.co.uk/parts-service/
An Ayrshire vintage tractor club may have members with info too: https://www.avtmc.co.uk
Mike
Thanks Mike, will pass those links on too.
Yes Agriparts is near me.
Note to those of us us spend big bucks on our cars , some of the tractor parts ar so cheap!
engine rebuild
[Edited on 29/8/19 by ReMan]
