Hi there
Anyone got a Racetech oil pressure gauge and sender the electric type, or just the sender..........
[Edited on 30/12/19 by striker-4age]
See: https://www.merlinmotorsport.co.uk/s/instruments-gauges-senders/racetech-gauges-and-instruments/electrical-gauges
Mike
There's two types of sender depending on the age, the older version is not available from Racetech any more but Intermotor do the correct one if
that's what your looking for.
Ian
Hi m8
Yes the older type of gauge I need the sender........intermotor?????
The older type Racetech oil pressure gauge works perfectly with Intermotor 53800 sender (identical sender/fitting and reads correctly).
Ian
Ian topman !!!!!!!!
