Morning, as usual every job on the kit escalates. I picked up a QR so purchased a new momo hub to allow this to fit. Now my steering wheel is a
mountney with the 6x100mm pcd so looking for an adaptor to go from 6x70mm momo to the 6x100 mountney traditional fitting.
The only ones i can find online are from B-G racing etc come in at £60 plus for a little plate, i can find loads for £10-25 but there are all the 3
bolt pcd adaptors.
Does anyone know of a cheaper one i require or have one lying around they wish to sell?
Thanks Mike.
I've looked many times. I think I did find one for 20 quid. Will look again and post a link of I can find it. I keep thinking how much could it cost to get one made,, but never ask anyone.
That would be great if you could. I would of thought there was quite a market for such an adaptor.
Sorry, this is the best i found
https://www.europaspares.com/hub-adaptor-plate-mountney.html
I may have what you need. Will check this evening.
Thank you very much TimC 🤞
If you can't get one off the shelf I can make one to dimensions.
