Hi all,
With such a mix of professions on here I was wondering if anyone had a source for tubing, ideally ptfe but I think anything will do.
I have a pitot tube which I'd like to hook up to a manometer and need probably about 15m (to be on the safe side) of some small tubing.
Would you think the tube should be the same size as the outlets on the pitot? I as as at the moment I've bodged some 5mm ID onto the pitot even
though the outlets are 2.5mm dia. I don't think this would be right for a long run of tube as the extra cross-sectional area will act as a damper
and the sensor wouldn't read accurately.
Thoughts please?
This might be of use?
https://www.lasaero.com/products/article/I00I217XF
Mike
Looking on the phone, it appears that they only do 6mm ID?
Here is who I use
http://www.processengineeringsupplies.co.uk/shop.htm
I don't think this would be right for a long run of tube as the extra cross-sectional area will act as a damper and the sensor wouldn't read accurately
4mm polyurethane/nylon/PTFE pneumatic tube is 2-2.5mm ID and easy to get hold of. It also suits standard pushfit fittings. The PTFE variant is
eyewateringly expensive compared to the others though.
Whether the volume of the tube you have at the minute is significant or not probably depends how transient the measured flow is. If you're really
worried, can you shorten the distance between pitot tube and sensor?
could you use teflon mig welder liner tube?
like
https://www.r-techwelding.co.uk/3m-teflon-mig-welding-torch-liner
or
https://stemweld.co.uk/products/teflon-mig-torch-liner-all-sizes
edit, different colours denote different sizes
https://www.basicwelding.co.uk/blogs/news/how-to-fit-a-teflon-liner-in-a-mig-torch
edit again
just noticed that you want 15meters, so maybe it won't help, unless you can gat a bulk length
[Edited on 10/1/22 by gremlin1234]
Smallest inner diameter possible unless you're looking for practically static pressure readings.
Originally posted by indykid
4mm polyurethane/nylon/PTFE pneumatic tube is 2-2.5mm ID and easy to get hold of. It also suits standard pushfit fittings. The PTFE variant is eyewateringly expensive compared to the others though.
Whether the volume of the tube you have at the minute is significant or not probably depends how transient the measured flow is. If you're really worried, can you shorten the distance between pitot tube and sensor?
having thought about it, why don't you use copper?
so a quick search found not much, - except pg 3, of this lists 30metre rolls of 0.075inch ~ 1.9mm internal diameter nylon tubing
https://www.johnsonvalves.co.uk/Data/Data%20Sheet%20No.%2032.01-02%20-%20Copper%20&%20Stainless%20Steel%20Tube.pdf
If you're happy making your own terminations, 0.5mm ID?
https://www.moddiy.com/products/High-Quality-F4-PTFE-Tubing-%252d-Transparent-(0.5mm-ID-x-1mm-OD).html?setCurrencyId=6
ETA:
Scratch that, 0.3mm diameter on ebay (from China)
https://www.ebay.co.uk/itm/391075062127
[Edited on 11/1/22 by indykid]
ETA:
ETA:
I bow to the superior finding skills.
