All, now in the final stages of my build I am in the need of the following - Zetec to MT75 with turbosport lightened flywheel and AP pressure plate
and CG clutch. I need to extend the MT75 release bearing by around 20mm. Does anyone have one of the old westie extended release bearing or have a
please with following dimensions etc:
40mm internal diameter
64mm external diameter
19mm/20mm thick
This is mentioned with diagram at the following:
http://www.turbosport.co.uk/showthread.php?t=84458
Any help with this would be gratefully appreciated.
cheers
Craig
If I remember correctly there are a couple of ways round it without using the spacer as Westfield did.
You can buy a different pivot pin from kit spares which then allows you to use the normal Sierra release bearing
https://kitspares.co.uk/products/mt75-clutch-arm-pin
Or I think you can use release bearing CT133 instead which is already longer and doesn't need the spacer.
[Edited on 19/2/22 by pmc_3]
Yeah, thanks for that - I have the pin but still my arm travel is around an inch which is why I am looking to the spacer for the thrust bearing
Iirc these were 19mm thick and were bonded to the face of the standard bearing
Trouble is they had a habit of coming off the bearing face and on my old westy with an MT75 it certainly did
I seem to remember the advice being to adjust the clutch so the spacer was just in contact with the fingers on the release plate, that way they
didn't get a 'shock load' when operating the clutch pedal
I'd use a different method of doing it if you can cable
GBS extend the release arm with an extended pivot. Mine was an early version with a M12 bolt which I had extended. I'm just going to replace this
with a longer bolt.
Thanks to all especially Big_Wasa for yours and his help.
Craig
