Long shot but does anyone have a set of 16" focus type wheels going spare for Mk3+ (2011 onward) ?
I think these are 6.5x16" ET50
or would anyone like to swap for some 18" versions ?
These kind of things? https://www.ebay.co.uk/itm/266040736114?
[Edited on 17/12/22 by Mike Wood]
Mondeo mk3/4 wheels are the same offset, mk2 focus is offset 2.5mm further outward, either should be good to fit, iirc the mk3 focus has a slightly
wider tyre (215/55 vs 205/55) but that is very minor , about 2.5% less on diameter / speedo reading if you use the exsisting tyres.
The steelies from a basic/lx mk2 focus will fit fine, as well as the alloy look steelies from a mk3.
Dave
