I have a fracture in the Manifold on my car.
I am looking for a Chrome-O-Zone Exhaust Manifold to fit 1600 Ford Kent Engine. The original was bought from Europa Car Spares as part of a full
system, 4-2-1 big bore.
Alternatively, if any one could recommend an exhaust fabricator who could copy the original it would be appreciated!
I have treid to get a replacement but the manufacturer has stopped production.
The original consisted of a Manifold which exited through the side or the body work, a mid section and a cherry-bomb back box. You may have knowledge
of them?
Can it not be repaired with welding ?
Unfortunatly no. The Clean break is in a position that requires the whole manifold to be welded in order to seal it.
I have been given a number of a fabricator, so fingers crossed!!!
Any other numbers much apreciated.
Have a talk to Martin at MK Engineering.
He does bespoke exhaust work.
http://www.mkengineering.co.uk/
