Does anyone know where i can get hold of a new ignition module (the little black box) for a early Sierra.
Michael
...and a little sachet of heat-conducting gloop that is spread between the module and the body of the dizzy. Otherwise you'll be looking for
another module shortly after!
NB: You can get suitable gloop from Maplins, sold as heat-sink compound.
How early a Sierra are you looking for. Ive got a dizzy and amp that i wont be using from a 2.0i Pinto - approx 1988 (E-reg).
I would happily swap for dizzy and amp from 1.6, 1.8 or pre'85 2.0 Pinto.
Many thanks for the offer Darren, however me thinks that we are both wanting the same part.
Michael
May be worth checking your local motor factor ?
if you have an old one take it along to match it up
Here is an interesting set up - not locost tho'.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=27377&item=4533661917&rd=1
I have been told that new amps can be sourced for sensible money. never tried it myself tho' as i need the dizzy as well.
You should be able to get it at any motor factors. The Quinton Hazel website lists them in the Ignition parts catalogue (ignition bits at
http://www2.qha.com/catalogues/ZC1-01.pdf & catalogue list at http://www2.qha.com/catalogue/downloads.asp)
John
