Good evening all.
I am in need of 4 M12 x38mm penny washers, and I'm having a few problems trying to get hold of some. I was wondering if anyone has any spare
knocking round, or perhaps knows where I could buy 4 of them?
cheers
namrick?
Where have you looked? Dont do to the mainstream high street places. I got a big selection of washers etc from a specialised engineering supplies
place. They are commonly found in industrial estates and back streets. Usually a lot cheaper than high street although you may have to buy packs of
100 etc.
I got 5l of brake fluyid from my local place for around the same price as 2 litres in Halfords.
Try yellow pages etc.
believe it or not - bought some from B&Q the other week!
Generally called mudguard or repair washers. As earlier posters have said, look up fastener suppliers in the local directory - only problem is a fair few now have minimum transaction qtys and/or insist on a/c's to deter low value transactions like car builders. If you get stuck I can stick four in the post.
It's funny you should mention the minimum order quantities. I;ve just checked with two local engineering suppliers, and they want £25 minimum
orders. Seems silly for 4 dinky washers!
I've got a few more places to try, but if that fails, then I might have to take you up on your offer Kissy.
Edit. It seems namrick don't supply them in metric sizes to suit an M12 bolt. i suppose I could drill them out though.
[Edited on 10/5/05 by bigandy]
buy 1/2" = 12.7mm !!!
Namrick don't stock the 1/2" penny washers either though.... They only go up to 3/8"...
What sort of two-bit outfit are they?
How thick ?
I've a few of M10x38x1.3 in stainless left over from a job.
Happy to let you have 'em for nowt
if you're happy to drill 'em out !
Quite poetic that
U2me your address if they're any good.
[Edited on 10/5/05 by Nige_S]
