Looking for an unfinished project to finish for myself ( first build dont and can't afford to buy a new kit), will consider most things my budget
is quite low, I'm thinking about £1000? Don't know whether thats likely or not.
Cheers Ian
Keep watch on ebay mate. Theres usually some on there.
Just do a search for locost.
Here's one
http://www.locostbuilders.co.uk/viewthread.php?tid=28392
I got one..
New Luego Viento (3/4 built)
Black Fibre glass and Polished Stainless Steel Sides Mmmmm!!
Rover V8, with Recon Lt77 Box (Box supplied by Luego)
rebore, new pistons, polished crank and new bearings.
New Cam bearings, new Hurricane Cam
New Rhoads Lifters.
New Cloyes timing gear and shain set.
New oil pump (gears and housing)
New valve springs (special single ones for the Cam.
Reground valves
mildly ported heads
New Weber 500 4 barrel carb and Edelbrock performer manifold and BIG Air Filter.
New Mallory Electronic Dizz (NOT twin contact one)
High voltage Coil
Polished Rocker box covers
New Clutch and hydraulics
Full Polished Stainless Steel Exhaust and cans (4 pots and a can each side) These cost nearly £1k alone)
All polished Stainless steel panels (except the internal tunnel (ally)
All new chassis, and suspension
Luego Arms
Stainless Steel Mushrooms on front hubs
New Gaz Shocks
New Greengauges and senders
New Cobra Roadster 7 seats Black / red piping, new seat runners
new Horns
New battery
Polished Stainless battery box
Polished Stainless battery shelf and bulkhead panel.
New Radiator and pipes
New Twin Fans
New electronic Thermostat and relay
All new brake pipes and fittings master cylinders and reservoirs..
New back discs capilers and pads
3.6 Sierra Limited Slip Diff
New Premier Wiring Loom 3/4 fitted (lights not done).
new headlights
New back lights rev and Fog in Carbon fibre holders.
Quick rack, ALL new ball joints (all round)
Carbon fibre effect dash
Luego Mirrors (two)
Cosworth leather steering wheel.
The List goes On....
Dont have:
Grill
Fire extinguisher
Interior trim (black pvc stuff / carpet)
Decent wheels, but have a set of good Escort Ally wheels with 2 good tyres and two just (maybee) legal ones.
All yours for £11000
www.v8viento.co.uk
