Anyone got any rusting away in the back of their garage?
Thanks,
Pat...
have some cortina wheel studs are they the same?
regards
Andrew
Not sure, think the Cortina ones are UNF???
Pat...
think that they are M12x1.5x63mm as
i had to get longer studs as i fitted 17" wheels and the standard studs where too short, so i have the extra long ones and the standard ones
these may be unf
regards
Andrew
As you say Pat the new studs are all one size. But I pressed a set into the cortina uprights ,fitted fine ...
Will be doing the same with the capri axle so just been out to the garage and pressed these out if you want them ?
would of offered to turn yours down but i dont think you should mess with them myself...
Hi Mate,
Can you mesure the length of the splined shoulder bit pretty please?
Pat...
Actually, don't bother..
I'll take them all!
How much do you want etc.....
Pat
Pat
I'll try and check the thread size of these bad boys and get back as soon as i can.
Hi Bob,
Cheers, but the shoulder looks too long for my application (don't ask).
Cheers anyway - you're always good for bits!
Pat...
Hi Pat actual splines are 6mm long then a 2mm taper to the thread, whole stud is about 36mm.
U2 me your address and ill try and get them out in a jiffy bag tommorow.....
regards warren
Hi Big W,
They are metric aren't they - pressume they are being from a Capri.
Address has been U2U's,
Cheers mate,
Pat...
yeh metric..
Your name for the the top of the jify bag would be good Pat
They arnt worth anything to me, so free if the postage isnt stupid...
Hi Big W (Could be a shop name that!)
Pat W, Avoneer, whatever you like!
Pat
