Can anyone who has a 2.0litre Mondeo tin top haynes manual help me out?
I need some info for setting up my MegaSquirt.
I need to know wht the Max Torque figure is and at what revs it is developed and the max BHP figure and again at what revs.
The third spec I need is a little more obscure and I'm not sure it will be in the Haynes manual but I need to know how much fuel the standard
injectors are capable of flowing, in either CC's per minute or lbs per hour.
Any help appreciated.
This site will help with the power figures, and I'm sure someone will have the injector info
or know where it is
Alex
if you ask, I'm sure there's a few people around here with base maps you can use as a starting point...
Try asking on This Group.
Got Haynes book open
Pre 4/1998 100kW @ 6000 rpm
Post 5/1998 96kW @ 6000 rpm
No torque figures to be found, or injector flow rates.
suspiciously round numbers for rpm IMO
probably useless I'm afraid.
Locally, a search for "zetec map" turns up
this and
this
and this
Thanks for the replies so far.
I forgot all about the Zeetec Cat site
That has the power/torque figures I needed for generating the base maps.
I still need the injector flow figures if anyone can help. if not I guess it will be a call to the Ford Technical help line at £1.00 a minute
Injector fuel rates are here (found link in PPC letters page
http://www.rsparks.com/tech_ref/fuel_injectors.html
Will need the serial numbers of the injectors as the list is rather UScentric in the vehicles column.
I still need the injector flow figures if anyone can help. if not I guess it will be a call to the Ford Technical help line at £1.00 a minute![]()
Thanks for that Stevebubs.
That sounds about right.
I was estimating about 500cc/min from some rough info I got from an Aussie tuning site that listed some Nippon Denso injectors
A value of 330 will give me a much better injection time in milliseconds as at 500 it was way too short.
